Hi guys,
is there a way to allow more than 10 tags in the PDoA procedure with DWM1002 (node) & DWM1003 (tag), without decreasing ranging frequency?
According datasheets there are 10 TDMA slots, which can be assigned to tags in the “KList”.
In the tag_list.h source code file I found:
//maximum is limited by NUM_SLOTS; FCONFIG_SIZE and available memory size, see default_config.h
#define MAX_KNOWN_TAG_LIST_SIZE (9) // MAX_KNOWN_TAG_LIST_SIZE = DEFAULT_NUM_SLOTS - 1 as Slot 0 is for Beacon
#define MAX_DISCOVERED_TAG_LIST_SIZE (9) // MAX_DISCOVERED_TAG_LIST_SIZE = DEFAULT_NUM_SLOTS - 1 as Slot 0 is for Beacon
Thus, I assume I have to increase MAX_KNOWN_TAG_LIST_SIZE. This constant depends on the slot configuration in default_config.h :
#define DEFAULT_SLOT_PERIOD_MS 10 /**< Slot period (ms), the best of what the implementation can achieve */
#define DEFAULT_NUM_SLOTS 10 /**< Number of slots: cannot be shorter than (MAX_KNOWN_TAG_LIST_SIZE + 1) */
#define DEFAULT_SF_PERIOD_MS 100 /**< SuperFrame period: cannot be shorter than NUM_SLOTS*SLOT_PERIOD */
Since DEFAULT_NUM_SLOTS = DEFAULT_SF_PERIOD_MS / DEFAULT_SLOT_PERIOD_MS and the slot period is already “the best of what the implementation can achieve” (…with this hardware?), it is not possible to increase the amount of tags within the PDoA system without decreasing the ranging frequency (100ms SuperFrame --> 10Hz). Or is there a way to decrease the default slot period?
