Hello, I’m trying to take my project to the next stage where several anchors will be working with several different tags to accomplish positioning.
Thing is, Decawave probably had done a lot of work on this already.
My question is what are the example projects that I can look into? I likely will be using some sort of TDMA scheme. But at the same time, I don’t mind examples of much simpler solutions, where only a couple of tags are supported.
Also when I was doing my research, the term “PANS” kept showing up. What is it about?
Hi @DoubleDeca
PANS (Positioning and Networking Stack) is RTLS system based on TWR scheme including IOT data transfer from/to server via MQTT. Pan is free to use but it has some limitations. Please see this doc: https://www.qorvo.com/products/d/da007972
Cheers
JK
Hi, so can I take it that other than PANS, there’s no other official example for multiple anchors to multiple tags scheme?
Hi @DoubleDeca
Im not a Qorvo guy and Im not much familiar with their examples so I cant answer your question if there is any example that supports your need.
Go ahead and try PANS (its for free).
Cheers
JK
