How to modify the default attributes of the Zigbee cluster?
1. In Application Code
- Each Zigbee cluster is represented by a class (e.g.,
CZigBeeClusterOnOff
,CZigBeeClusterTemperatureMeasurement
). - You can set or override default attribute values in your application’s initialization or reset logic.
- For example, to restore or modify default attributes, you might use functions like
RestoreDefaults()
orRestore[Cluster]AttributeDefaults()
in your application code.
Example:
void CLightApplication::RestoreDefaults(const bool bRemoveAllReferences)
// Reset Basic cluster attributes to defaults
RestoreBasicAttributeDefaults();
// Reset Identify cluster attributes to defaults
RestoreIdentifyAttributeDefaults();
// Reset Scene, On-Off, Leveling, etc.
RestoreSceneAttributeDefaults();
RestoreOnOffAttributeDefaults();
RestoreLevelingAttributeDefaults();
You can modify the implementation of these functions to set your desired default values for each attribute.
2. At Attribute Level
- Each cluster class has attribute members (e.g.,
m_OnOff
for On/Off). - You can set their default values in the class constructor or in the reset-to-factory-defaults logic.
Example:
CZigBeeClusterOnOff::CZigBeeClusterOnOff(...)
m_bOnOff = false; // Set default OnOff state
Or use SetAttributeValue()
to programmatically change an attribute at runtime.
//Method one
ASSERT(pCurrentScene);
m_scenes.SetAttributeValue(*pCurrentScene, &m_scenes.m_nCurrentScene, sizeof(m_scenes.m_nCurrentScene));
//Method two
/** @brief Instance of on-off cluster */
CZigBeeClusterOnOffEx m_onOff;
void CLightApplication::SetOnOffAttribute(const bool bOnOff, const bool bPowerup)
// set on-off attribute
m_onOff.SetValue(bOnOff, bPowerup);
3. Via Persistent Storage (PSB/NVM)
- You can define default attribute values in the PSB XML file.
- When the device is reset or starts up, it will load these defaults from NVM.
- This is useful for attributes that should persist across reboots or factory resets.
4. Reset to Factory Defaults Command
- The Zigbee Basic cluster supports a “Reset to Factory Defaults” command.
- When this command is received, your application should reset all supported cluster attributes to their default values as defined in your logic or PSB.
