I am able to replicate the basic serial connection, data receive, and trilateration functionality of the DecaRange RTLS PC program on a Raspberry Pi (or similar microcontroller) without the GUI functionality? Would this require a massive rewriting of the DecaRanging PC source code?
In the case that the PC Widget is inextricably written into the serial data stream, must I bypass the ARM processor and replicate that functionality on my Pi? I’m using the TREK1000 system. Can I build the TREK1000 source code on my Pi, or must I rewrite for the Pi? If I must rewrite, which source files and headers should I keep, which can I discard, which should I rewrite?
The TREK source code describes how TREK works. Basically the TAG ranges to all anchors, while the Anchors communicate between them also.
Anchor 0 is the one which spills out all the data to the PC.
So, you could capture / process this data using the USB. SPI or UART (which requires green wiring).
The Trek algorithm we’re using is based on : [color=#1f497d][size=small][color=#0000ff]https://en.wikipedia.org/wiki/Trilateration[/color][/size][/color]
The option is to write/develop your solver/ GUI from scratch or use (parts of ) the source code available from our website
/leo
From what I understand, is Anchor 0 also listening for data from the other anchors in order to compute the tag location via the trilateration algorithm?
