I am planning to do a DW1001 setup using 10 Anchors, 1 Listener and more than one Tag moving around at a sampling/update frequency of 10 Hz, which is the highest possible.
Does anyone of you know how many tags I am able to use in order to have an update frequency of 10Hz on each tag?
Thank you so much!!
Hi blubbus,
Maybe take a look at the system performance and overview guide.
The system supports 15 tags at 10Hz update rate, but slot can be reused, so if you have a very large network, you may have more than 20 tags at 10 Hz for example (but not all in the same area.)
