Max input voltage MDEK1001 charger
I have a small solar panel that I would like to connect to the MDEK1001. It peaks a 6.2 volts. USB max is around 5.6 volts. Does anyone know the max voltage input to the charger via mini HDMI?
Did you mean micro-usb ?
Please see the dwm1001-dev datasheet section 1.1 for input voltage.
Regards
Yes, I did mean micro usb. Thanks for the info.
