I am going to track the position of a robot using DWM3001CDK. I figured out how to build the CLI application hex file and observed the calculated UWB parameters such as distance, responder address and so on. Now I want to send those data (distance, address … ) from DWM3001CDK boards to my laptop over Bluetooth or any other method. I am going to use three anchors and I need to send the UWB calculated parameters between those anchors and tag to a central unit like PC over Bluetooth or any other method.
If anyone has suggestion I would really appreciate. Thanks in Advance!!!
I am new with DWM3001CDK. How did you program the board?
Are there any drivers, board device tree file or documantation online?
This would be really helpfull for me.
Binary and Source code of CLI (Command Line interface) version.
Binary and Source code of UCI (Universal Command Interface) version to be used together with QorvoOne GUI or with Python Scripts provided inside the package.
Hi @Wassim_Qorvo , Thank you very much for your suggestion. One thing I wanted to know, how do we get the data over uart pins in dwm3001CDK instead of usb. Do I need to do some modifications in the CLI code?
