Is QSPICE supports SystemVerilog? Is there C API reference for C written modules? Is possible to configure QSPICE in way that DLL loaded by simulator will be provided “externally” (aka builded by different compiler according to QSPICE C API)
Hi, musialny.
I’m not a Verilog guy but you can build C-Block components using any tools that produce a proper Win32 DLL. I use MinGW and MSVC regularly with no problems using VSCode as an IDE.
I have some additional information for using other compilers on
my QSpice GitHub repository. Maybe that will help.
–robert
Yes. SV supports with features of Verilator. “Name.v” must be used instead of " .sv"
I will add. Sometimes incomprehensible problems arise - try to close Qspise, delete all files in the working directory except the .qsch and verilog files. And run it again.
