Hello, good afternoon.
Is it possible to write latex text in QSpice?
Hi, Julio.
I’m not sure that I understand the question. Write Latex code to what, from where? Maybe you could clarify?
–robert
Hello, good evening.
I want to write some equations to ilustrate whats happening in simulation. Just for documentation, as commentaries in QSpice.
Hi, Julio.
As far as I know, QSpice doesn’t support LaTeX. You have a couple of options:
A note about the last item: I’ve not tried PDF but there’s a built-in “print to PDF” Windows driver. For SVG, I’ve tried the open source ClawPDF tool (here) which provides an SVG printer driver. That can be imported to Inkscape for editing with reasonable results.
Hope that helps. Maybe someone else will have a better solution.
–robert
Hello, thank you. I really apreciate. I will install the svg driver, than I can do things with inkscape.
Hi jgardona,
If you plot QSPICE schematic to .pdf, you can open this .pdf file with Inkscape (right-click and select Inkscape). Delete the filename string at the bottom, lock schematic and add a layer for Latex formulas and comments. Add your equations. In Documents Properties, select Resize to content and save.
Best Regards
Bent
Nice Idea. I very appreciate.
