Interfacing DWM1001 Module
Can DWM1001C Module be interfaced without the DWM1001-DEV board? If so what are the options?
Hi @Abishek
yes the board can be interfaced without the DWM1001-DEV board. You need to apply 3.3V to power pins and they you can interface it with other MCU/stuff.
Cheers
JK
can USB-UART converters like FT232, CP2102, CH34 or any other USB TTL Converters be used to program it directly ?
Hi @Abishek
unfortunately not, you need some SWD programmer to upload the firmware into the DWM1001 module.
Cheers
JK
thanks for the clarification.
What debugger would you suggest? because of the unavailability of the segger J-link debug, lack magic probe. Can you give me some other options?
Thanks.
Hi @Abishek
Mouser & DigiKey have a plenty of debug probes in stock (https://eu.mouser.com/c/?q=J-LINK%20BASE , https://www.digikey.com/en/products/detail/segger-microcontroller-systems/8-08-00-J-LINK-BASE/2175882)
Cheers
JK
Instead of J-link, can ST-link be used to debug, without any STM boards but directly with the DWM1001C module? they seem to have same specifications as that of J-link.
Regards,
Abishek
Hi @Abishek
I have no idea. In theory it should be possible as the ST-link contains lined for SWD programming - check this post microcontroller - Can I use ST-Link programmer for non-ST chips? - Electrical Engineering Stack Exchange
Cheers
JK
