Hello, guys
i am trying to make pi compensator block and current controller block which contain two pi compensator blocks.
when current controller contains two integrators and is used in a schematic,how to set different initial values for each integrator in the schematic?
Here is how to set initial conditions for two idts.
Untitled_X1.qsch (2.4 KB)
Untitled.qsch (2.8 KB)
Best regards
Why is needed that 1G R1 resistor?
R1 is there only to act as a ground reference, probably you don’t need to add it.
Best regards
