Include Directive Issue
Hello gentlemen,
I’m trying to use #include “abc.h” directive but I’m getting errors when the C block is being compiled.
C block code in QSPICE:
// Automatically generated C++ file on Tue May 28 11:00:28 2024
// To build with Digital Mars C++ Compiler:
//    dmc -mn -WD cblock_include_test_x1.cpp kernel32.lib
#include "controller_pid.hpp"
#include <stdint.h>
union uData
   bool b;
   char c;
   unsigned char uc;
   short s;
   unsigned short us;
   int i;
   unsigned int ui;
   float f;
   double d;
   long long int i64;
   unsigned long long int ui64;
   char *str;
   unsigned char *bytes;
bool init = true;
PID_t ControllerPID_Obj;
// int DllMain() must exist and return 1 for a process to load the .DLL
// See https://docs.microsoft.com/en-us/windows/win32/dlls/dllmain for more information.
int __stdcall DllMain(void *module, unsigned int reason, void *reserved) { return 1; }
// #undef pin names lest they collide with names in any header file(s) you might include.
#undef OUT
#undef FB
extern "C" __declspec(dllexport) void cblock_include_test_x1(void **opaque, double t, union uData *data)
   double  FB  = data[0].d; // input
   double &OUT = data[1].d; // output
// Implement module evaluation code here:
   if(init){
      PIDinit(&ControllerPID_Obj, 1.0f, 0.1f, 0.0f, 1.0f);
      PIDSetRef(&ControllerPID_Obj, 10);
      init = false;
   OUT = PIDRun(&ControllerPID_Obj, FB);
Here is the compiler output:
link cblock_include_test_x1,cblock_include_test_x1.dll,,verilated+kernel32,cblock_include_test_x1/noi;
OPTLINK (R) for Win32  Release 8.00.16
Copyright (C) Digital Mars 1989-2013  All rights reserved.
http://www.digitalmars.com/ctg/optlink.html
cblock_include_test_x1.obj(cblock_include_test_x1)
 Error 42: Symbol Undefined ?PIDSetRef@@YAXPAUPID_st@@M@Z (void cdecl PIDSetRef(PID_st *,float ))
 Error 42: Symbol Undefined ?PIDinit@@YAXPAUPID_st@@MMMM@Z (void cdecl PIDinit(PID_st *,float ,float ,float ,float ))
 Error 42: Symbol Undefined ?PIDRun@@YAMPAUPID_st@@M@Z (float cdecl PIDRun(PID_st *,float ))
--- errorlevel 3
controller_pid_hpp
#ifndef CONTROLLER_PID_H__
#define CONTROLLER_PID_H__
typedef struct PID_st{
   float ref;        // reference value
   float fb;         // feedback value
   float err;        // error
   float sat_high;
   float sat_low;    //
   float integral;   // integration value
   float integral_prev;
   float out_p;
   float out_i;
   float out_d;
   float out;
   float kp;   // proportional coef
   float ki;   // integral coef
   float kd;   // derivative coef
   float kc;   // anti-windup
}PID_t;
 * @brief
 * @param pidObj
 * @param feedback
 * @return float
float PIDRun(PID_t *pidObj, float feedback);
* @brief
void PIDinit(PID_t *pidObj, float kp, float ki, float kd, float kc);
 * @brief
 * @param pidObj
 * @param ref
void PIDSetRef(PID_t *pidObj, float ref);
 * @brief
 * @param pidObj
 * @return float
float getPIDref(PID_t *pidObj);
 * @brief
 * @param pidObj
 * @return float
float getPIDerror(PID_t *pidObj);
#endif  // CONTROLLER_PID_H__
controller_pid.cpp
float PIDRun(PID_t *pidObj, float feedback){
   pidObj->fb = feedback;
   pidObj->err = pidObj->ref - pidObj->fb;
   pidObj->out_p = pidObj->err * pidObj->kp;
   pidObj->out_d = pidObj->err * pidObj->kd; // Wrong implementation for derivative
   pidObj->integral = pidObj->err * pidObj->ki;
   pidObj->out_i = pidObj->integral + pidObj->integral_prev;
   pidObj->integral_prev = pidObj->out_i;
   pidObj->out = pidObj->out_p + pidObj->out_i + pidObj->out_d;
   return pidObj->out;
void PIDinit(PID_t *pidObj, float kp, float ki, float kd, float kc){
   pidObj->kp = kp;
   pidObj->ki = ki;
   pidObj->kd = kd;
   pidObj->kc = kc;
   /*pidObj->out_i = 0;
   pidObj->integral_prev = 0;
   pidObj->fb = 0;
   pidObj->ref = 0;*/
void PIDSetRef(PID_t *pidObj, float ref){
   pidObj->ref = ref;
void PIDSetFeedback(PID_t *pidObj, float feedback){
float getPIDref(PID_t *pidObj){
   return pidObj->ref;
float getPIDerror(PID_t *pidObj){
   return pidObj->err;
What am I missing?
Thank you
