Hi All,
I know that we can zoom in on the waveform viewer by dragging a rectangle while pressing the left mouse.
But I dont think if I can pan, zoom in/out… is these feature not yet implemented?
Thanks,
Arief,
Hi All,
Thanks,
Arief,
@physicboy ,
On the plot, make sure the “+” mouse cursur is on the plot and the plot window is the active window.
Press the “Alt” key ONLY and move the mouse.
Viola … Panning.
Ah… I skipped that combo, thanks
Any clue for zoom in/out?
Arief
What works for me in the plot window is:
Press the “Alt” key ONLY and then use the scroll wheel on most modern mouses to Zoom in (wheel up) or Zoom out (wheel down).
Len
Hi @lpoma
1st… oh your name is LPOMA not IPOMA…haha
yes the “alt” works, however its very dizzying where my screen blanking black repeatedly when I press “alt” and I cant really see how I move my waveform until I release the “alt”.
To be clear my PC dont have dedicated GPU, however it never been an issue with other simulator…
@Engelhardt , any suggestion?
Thanks,
Arief,
Could this be broken in newer releases of Qspice? When I hold the Alt down, and move the mouse, the whold plot window moves; ie, it is not panning. If I hold alt and scroll the mousewheel, the plot window zooms in and out.
I’m using Windows 11, and the current version of Qspice,
When I use ALT and move the mouse, the whole window moves as you said.
This is because the plot window initially displays the entire available sim timing from SIM_TIME_START to SIM_TIME_STOP.
If I zoom in to a smaller time section of the plot, then I ALT mouse move left then unpress the ALT, the timing pans correctly. If I ALT mouse move right then unpress the ALT, the timing pans correctly.
Is this what you are looking to do?
What I did notice is that every time I panned (left or right) without pressing a mouse button or mousewheel, it always pans (intended) but also zooms in (undesired).
Len
Maybe we just need a simple feature: the Y-axis remains unchanged when X-axis is moved.
The shortcut key can be scrolling the mouse wheel with SHIFT or ALT pressed.
– Peter
ALT panning seems to be multiple direction panning.
Someone has to make a request to Mike for x-axis only panning, but I am not a fan of panning plots. It would be better if someone truly in need makes the request.
How about using Ctrl-W to open an empty window in the waveform viewer and then pan that window? It appears that only window in panning may change its y-axis, while other windows seem to remain untouched in their y-axis scaling.
