I’m using a DWM3001CDK with an iPhone via Apple’s Nearby Interaction framework. The measured ranging update rate is around 6.15 Hz with a single anchor.
Is there any way to increase it to 10–20 Hz or higher through firmware settings, or is it limited by Apple’s Nearby Interaction framework?
Thanks for the clarification! By “anchor,” I mean the DWM3001CDK acting as a fixed UWB accessory for indoor localization.
If the iPhone controls the ranging rate, is there any accessory configuration or firmware parameter that can influence the rate selected by the iPhone?
Or is approximately 6 Hz the expected rate when using Nearby Interaction?
There is very little flexibility on the tag side to change this behavior. The only way to influence this rate is through the preferredUpdateRate value in the send_accessory_config_data() function within our ble_niq.c file:
These values are fixed and cannot be modified. In general, foreground operation is associated with PreferredUpdateRate_UserInteractive, while background operation is associated with PreferredUpdateRate_Infrequent. However, the final update rate decision is ultimately made by the phone’s operating system.
