Sub-Register 0x2E:0000 – LDE_THRESH contains the threshold used for leading edge detection which is based on the noise estimate and the LDE_CFG1 and LDE_CFG2 values.
How is this value arrived at?
LDE_CGF1 : PMULT is described as “factor by which the peak value of estimated noise is increased in order to set the threshold for first path searching” with a value of 3 = x1.5 but no mention of how this is calculated so there is no indication of how changing this is going to impact results.
LDE_CGF1 : NTM is described as “factor by which the observed noise level is multiplied to set the threshold for the LDE algorithm’s first path search”
Sub-Register 0x12:0000 - RX_FQUAL includes STD_NOISE “the standard deviation of the noise level seen during the LDE algorithm’s analysis of the accumulator data”
Which based on those descriptions would make me think that the threshold should be something along the lines of STD_NOISE * PMULT * NTM or STD_NOISENTM + PMULTPeakNoise (where peak noise is defined as ???)
And LDE_THRESH is indeed somewhere in that region but there doesn’t seem to be any real relationship between them. There are clearly some other values that are being factored into the calculation but I can’t see any mention of what they are in the documentation.
And then there is 0x2E:1806– LDE_CFG2 which for LOS should be 0x1607 or 0x0607 for 16 MHz or 64 MHz PRF or 0x0003 for NLOS but beyond that is completely undocumented.
