How can I show two FFTs in common plot?
I could show two FFTs in common plot in LTSpice, how do I do it in QSPICE.
  1. In waveform viewer, right click → FFT
  2. Add waveforms for FFT, marked in yellow
  3. Click OK
Best regards
Ivan: thanks for the tip, but I don’t get anything in yellow.
What am I doing wrong
I was refering to the picture i attached. You need to click on waveforms that you want to add. Waveforms that you have added you can see in expression tab.
Best regards
Thanks. I think I figured it out. I first have to add the waveforms to the time domain display THEN i can view them in the FFT. I switching over from LTSpice and things are a little different.
