How can i reinstall previous build of Qspice? (dll. file compile error)
I have been using verilog dll block in my qspice simulation. The code was working completly fine with the previous version. But right now, after updating my qspice, when i tried to recompile my verilog code it created a different dll file than the previous one and the result of the simulation is not as expected.
I’m looking version earlier this year or maybe Nov-Dec 2025, since i need to made some adjustment to the code.
Officially, there are no earlier versions available, but I will PM the Oct-25 and Nov-25 versions to you.
It would be better if you could identify what the problem is and report it to Mike. This could help either fix a bug or identify a change that is necessary for the new version of QSpice to work.
Thank you, i have received your massage and yes, the build is working in the previous version.
I also have sent email to Mike before, and just got the reply back. It’s because he enabled more optimization in the compiler. So they are trying to fix it now.
