[Help] Ideal comparator: Inverting comparator with hysteresis
I’m trying to build a hysteretic current controller using KSKelvin’s ideal comparator.
When I test the hysteresis comparator with a sinusoidal input, it works perfectly. However, when I integrate the controller into a branch that emulates a buck converter, the system no longer behaves correctly.
I would appreciate any help or suggestions on what might be causing this issue.
Thank you in advance.
Hysteresis_current_control.qsch (14.2 KB)
There are at least two types of hysteresis comparator circuits. I think you have to use the HMITT comparator to build that instead of my ideal comparator. I saw that you used HMITT with Vt and Vh, so do you specifically want to build it with a resistor network?
I also made custom symbols for them in this directory: Hysteresis-CKT...
Qspice/Symbols-KSKelvin/devices/comparators at main · KSKelvin-Github/Qspice
concept.Hysteresis-CKT.qsch (6.9 KB)
concept.Hysteresis-CKT-InvertedOutput.qsch (6.1 KB)
Thank you very much, Kelvin. Changing to the HMITT comparator solved the issue and the circuit now works perfectly.
By the way, were you proposing an alternative solution? I saw your comment regarding the resistor network and would be interested in learning more about that approach.
This is what I refer to Vh, Vt with HMITT. (this is for simulation only)
Resistor network is what I posted and you highlighted as solution. (this can be built)
I see. No my hysteresis circuit was the following one:
But it did not work well with the ideal comparator.
Do you know you can config a HMITT with Vh and Vt to achieve hysteresis? If you just looking for such function and not a practical circuit to implement.
concept.Hysteresis-CKT-InvertedOutput-compare-HMITT.qsch (7.9 KB)
I have a device guideline in my Github, you can search HMITT in this pdf for more information
current from p.331, and this is direct download link
https://github.com/KSKelvin-Github/Qspice/raw/main/Guideline/Qspice%20-%20Device%20Reference%20Guide%20by%20KSKelvin.pdf
