TI Pspice model, TI Tina model, TI Spice, Import model
Well, one of the common questions in Qspice forum is that the Texas Instruments (TI) SPICE model doesn’t work. This is an instructional guide that can help you out.
Part 1: Get the model
TI may provide a PSpice Model or a TINA-TI SPICE Model; both can work in Qspice. In this guideline, I use the OPAx392 as an example, and here is the link: https://www.ti.com/product/OPA392#design-tools-simulation
You can download either the PSpice or TINA-TI SPICE Model along with the Reference Design (I suggest PSpice files, as its schematic will be easier to understand). After downloading and unzipping the file, the model file is named with the extension .lib.
Now, use a text editor to open this .lib file (you can rename it to .txt, or just open the .lib file from a text editor), and take a look to ensure it is an unencrypted file. An encrypted file is full of binary data. An unencrypted file contains a readable netlist. If you cannot find an unencrypted model, contact TI yourself. Please don’t ask if Qspice can read encrypted models; it is impossible since encrypted files are specifically designed for that simulation platform.
Part 2: Before importing the model to Qspice
If you need to read this guide, you may not have in-depth experience in using SPICE. I highly recommend that you DON’T try to build a Qspice schematic from datasheet circuits! TI SPICE models are generally very complex, and you just don’t know if they will work with the circuit you build.
TI offers two free SPICE tools: one is PSpice for TI, and the other is TINA-TI. Please download them! You need to register to get PSpice for TI. Again, please download them.
https://www.ti.com/tool/PSPICE-FOR-TI
https://www.ti.com/tool/TINA-TI
The reason is that you should build your first circuit following the PSpice or TINA examples.
Use these tools to open the demo schematic, and the first circuit you build in Qspice should be this circuit. Remember, all members in the forum are volunteers (including myself)!! Build something that you can guarantee will work, instead of your random stuff.
The PSpice project file is .OPJ. Open it. Two things are important for you: one is the schematic (demo circuit), and the other is the simulation profile (how to set up simulation directives).
