I’m having difficulty with proper configuration. I’ve been able to create the RTLS network properly but joining it is remains an issue. In order to carry out this step the gateway PanID must be configured. I notice the requisite scripts are in the directory but when I attempt to open them using Vi i get a blank document. Is this correct or should I edit it as the image on the deployment guide suggests?
check the file names the gateway guide command is misstyped. if i remember correctly its not .conf but .config
