I couldn’t find any published report of a Samsung phone ranging with a DWM3001CDK (every success I found was a Pixel), so here is one: it works, at least with one board.
Setup
- Phone: Galaxy S24 Ultra, SM-S928B, Android 17 (One UI 9), build S928BXXS6EZJ1. Its UWB chip should be NXP SR200-family going by S24 Ultra teardowns (not checked on this unit).
- Board: DWM3001CDK running the stock
DWM3001CDK-UCI-FreeRTOS.hexfrom DW3_QM33_SDK 1.1.1, flashed through J9 with J-Link Commander. No firmware changes, no rebuild. - Board side: Qorvo’s own
run_fira_twr.py(uwb-qorvo-tools, SDK 1.1.1) over the J20 USB port, as controlee / responder. - Phone side: no app code. The phone was controller / initiator through the shell command
cmd uwb start-fira-ranging-session, which the shell user is allowed to run on this retail build (as arestatus,get-ranging-session-reportsandstop-all-ranging-sessions;get-uwb-stateis not).
I used byte-symmetric values throughout (addresses 0x1111 / 0x2222, vendor ID 0x0808, static STS IV 08 x 6) so byte-order mistakes could not cause a failure.
Board (PC):
python run_fira_twr.py -p COM14 --controlee -t 30 -s 42 -c 9 --preamble-idx 9 \ --mac 0x2222 --dest-mac "[0x1111]" --vendor-id 0x0808 --static-sts 0x080808080808 \ --round ds-deferred --node unicast --slot-span 2400 --slots-per-rr 25 \ --ranging-span 200 --aoa-report all-disabled --frame sp3 --hopping-mode disabled
Phone (started a few seconds after the board):
adb shell cmd uwb start-fira-ranging-session -i 42 -c 9 -p 9 -t controller -r initiator \ -a 4369 -d 8738 -m unicast -u ds-twr -l 200 -s 25 -h 2400 -o static \ -v 0808 -g 080808080808 -e none -y disabledadb shell cmd uwb get-ranging-session-reports 42adb shell cmd uwb stop-all-ranging-sessions
(-a 4369 and -d 8738 are 0x1111 and 0x2222 in decimal.)
Result
- 20 s run at 200 ms: 103 of 103 rounds
Okon the board once the phone started (the board’s earlier rounds wereRangingRxTimeoutwhile it waited). - The phone reported 1.28–1.33 m to address 0x2222, status 0, RSSI about −82 dBm, line of sight on nearly every report. The board measured 125–136 cm (median 130).
- A second 10 s run: 52 of 52.
- Distances were not checked against a tape: this board’s antenna-delay calibration is off at the moment, so treat the numbers as “it ranges”, not as accuracy.
Python 3.12 note for uwb-qorvo-tools
The tools declare Python 3.9–3.10. On 3.12, importing uci fails with AttributeError: type object 'Gid' has no attribute 'Qorvo': DynIntEnum.extend adds members only to _member_map_, and 3.12 no longer falls back to _member_map_ on attribute lookup. A small wrapper restores that lookup and runs any of the scripts unchanged (only pyserial and colorama are needed for the ranging scripts):
# uqt_run.py <script.py> [script args...]import enum, pathlib, runpy, sys
def _member_fallback(cls, name): if name.startswith("_"): raise AttributeError(name) try: return cls.__dict__["_member_map_"][name] except KeyError: raise AttributeError(f"{cls.__name__} has no member {name!r}") from None
enum.EnumType.__getattr__ = _member_fallbackscript = pathlib.Path(sys.argv[1]).resolve()tools = next(p for p in script.parents if (p / "lib" / "uwb-uci").is_dir())sys.path[:0] = [str(tools / "lib" / "uwb-uci"), str(tools / "lib" / "uqt-utils"), str(tools)]sys.argv = [str(script)] + sys.argv[2:]runpy.run_path(str(script), run_name="__main__")
Not tested yet
- Several boards in one session (one-to-many / multicast DS-TWR).
- Ranging from an app through the
android.rangingAPI with a fixed phone address, rather than through adb. - CLI-firmware anchors that start on their own without a PC.
If anyone has run a one-to-many session from a Galaxy, I’d be glad to compare settings. I’ll post an update when I get there.
