Hi, I am trying to simulate an inductor model that has frequency dependent resistors in it. I used behavioral resistors B1 and B2, but the output bode plot doesn’t make sense.
The frequency dependent resistors are as follows:
B1 = K1 * sqrt(frequency)
B2 = K2 * sqrt(frequency)
The bode plot makes sense when I replace the variable s in the R=K2 Laplace=K2*sqrt(s) with any other parameter, such as x. But according to the help document I should put s, and with s the result does not seem correct.
Could you please advise what is the best way to implement this frequency dependency?
Thanks.
Erfan
