Floating Node Issue with Behavioral Current Source
Hi everyone,
I’m working on a linear PWM switching model operating in voltage mode. The model uses behavioral current and voltage sources to represent the average behavior of a boost converter single pole double throw (SPDT) configuration.
I’ve encountered an issue with the behavioral current source (B3): the simulator reports that the negative terminal is a floating node. In my design, the negative terminal is connected to GND, and the positive terminal connects to GND through C1 and R4, so the circuit should be complete.
Here’s a snapshot of the configuration:
Has anyone experienced this before? Any ideas on what might be causing this issue or how to resolve it would be greatly appreciated.
Thank you!
To review your case, it is possible that your simulation file is needed. Upgrade to a basic member to gain access to file upload capabilities.
Qspice Forum - New User to Basic User (File Upload) - QSPICE - Qorvo Tech Forum
