I would like to use the extended frame mode in an application on DW33110. When the extended frame mode is enabled, noticed that the frame filtering on the destination address is not working.
Is there any way, that frame filtering is possible in the extended frame mode.
In case if this feature is not possible, is there any DW APIs which can be used as a workaround to filter the extended frame before the Rx callback.
Thanks in advance
Sunil
