Ndw3000.h same as dw3000.h here i attached my code
not allowed me attch code here i will copy my anchor and tag code below
#include “dw3000.h”
#define ANCHOR_ADD “81:17:5B:D5:A9:9A:E2:9C”
static uint8_t Address[] = {0x81, 0x17, 0x5B, 0xD5,0xA9, 0x9A,0xE2, 0x9C};
static uint16_t Address1 = 0x8117;
// connection pins
const uint8_t PIN_RST = 27; // reset pin
const uint8_t PIN_IRQ = 34; // irq pin
const uint8_t PIN_SS = 4; // spi select pin
uint16_t Adelay = 16539;//16965;
float average =0;
uint16_t Average_Counter = 0;
unsigned char Ranging_Done = 0;
volatile int Enable_receive_Blink = 1;
volatile int Transmit_blink_en = 1;
String T ;
String Prv_Tag_ID;
byte Prv_SeqNum_ID ;
String Data;
const int numReadings = 10;
float readings [numReadings];
int readIndex = 0;
float total = 0.0;
byte seqnum;
/* Default communication configuration. We use default non-STS DW mode. */
extern void test_run_info(unsigned char *data);
/* Example application name */
#define APP_NAME “DS TWR RESP v1.0”
/* Default communication configuration. We use default non-STS DW mode. /
5, / Channel number. /
DWT_PLEN_128, / Preamble length. Used in TX only. /
DWT_PAC8, / Preamble acquisition chunk size. Used in RX only. /
9, / TX preamble code. Used in TX only. /
9, / RX preamble code. Used in RX only. /
1, / 0 to use standard 8 symbol SFD, 1 to use non-standard 8 symbol, 2 for non-standard 16 symbol SFD and 3 for 4z 8 symbol SDF type /
DWT_BR_6M8, / Data rate. /
DWT_PHRRATE_STD, / PHY header rate. /
(129 + 8 - 8), / SFD timeout (preamble length + 1 + SFD length - PAC size). Used in RX only. /
DWT_STS_MODE_OFF, / STS disabled /
DWT_STS_LEN_64, / STS length see allowed values in Enum dwt_sts_lengths_e /
DWT_PDOA_M0 / PDOA mode off */
/* Inter-ranging delay period, in milliseconds. */
#define RNG_DELAY_MS 1000
/* Default antenna delay values for 64 MHz PRF. See NOTE 1 below. */
#define TX_ANT_DLY 16385
#define RX_ANT_DLY 16385
/* Frames used in the ranging process. See NOTE 2 below. /
static uint8_t rx_poll_msg[] = { 0x41, 0x88, 0, 0xCA, 0xDE, ‘W’, ‘A’, ‘V’, ‘E’, 0x21, 0, 0 };
static uint8_t tx_resp_msg[] = { 0x41, 0x88, 0, 0xCA, 0xDE, ‘V’, ‘E’, ‘W’, ‘A’, 0x10, 0x02, 0, 0, 0, 0 };
static uint8_t rx_final_msg[] = { 0x41, 0x88, 0, 0xCA, 0xDE, ‘W’, ‘A’, ‘V’, ‘E’, 0x23, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 };
/ Length of the common part of the message (up to and including the function code, see NOTE 2 below). /
#define ALL_MSG_COMMON_LEN 10
/ Index to access some of the fields in the frames involved in the process. /
#define ALL_MSG_SN_IDX 2
#define FINAL_MSG_POLL_TX_TS_IDX 10
#define FINAL_MSG_RESP_RX_TS_IDX 14
#define FINAL_MSG_FINAL_TX_TS_IDX 18
/ Frame sequence number, incremented after each transmission. */
static uint8_t frame_seq_nb = 0;
/* Buffer to store received messages.
- Its size is adjusted to longest frame that this example code is supposed to handle. */
#define RX_BUF_LEN 24
static uint8_t rx_buffer[RX_BUF_LEN];
/* Hold copy of status register state here for reference so that it can be examined at a debug breakpoint. */
static uint32_t status_reg = 0;
/* Delay between frames, in UWB microseconds. See NOTE 1 below. */
#ifdef RPI_BUILD
#define POLL_RX_TO_RESP_TX_DLY_UUS 550
#endif //RPI_BUILD
#ifdef STM32F429xx
#define POLL_RX_TO_RESP_TX_DLY_UUS 450
#endif //STM32F429xx
#ifdef NRF52840_XXAA
#define POLL_RX_TO_RESP_TX_DLY_UUS 650
#endif //NRF52840_XXAA
#define RESP_TX_TO_FINAL_RX_DLY_UUS 450
#define FINAL_RX_TIMEOUT_UUS 450
/* Preamble timeout, in multiple of PAC size. See NOTE 6 below. */
#define PRE_TIMEOUT 50
/* Timestamps of frames transmission/reception. */
static uint64_t poll_rx_ts;
static uint64_t resp_tx_ts;
static uint64_t final_rx_ts;
/* Hold copies of computed time of flight and distance here for reference so that it can be examined at a debug breakpoint. /
static double tof;
static double distance;
/ Values for the PG_DELAY and TX_POWER registers reflect the bandwidth and power of the spectrum at the current
- temperature. These values can be calibrated prior to taking reference measurements. See NOTE 2 below. */
extern dwt_txconfig_t txconfig_options;
unsigned char msg11[90];
uint16_t add = 0;
void setup() {
// DEBUG monitoring
Serial.begin(115200);
/* Display application name on LCD. */
test_run_info((unsigned char )APP_NAME);
/ Configure SPI rate, DW3000 supports up to 38 MHz /
/ Reset DW IC */
spiBegin(PIN_IRQ, PIN_RST);
spiSelect(PIN_SS);
Sleep(2); // Time needed for DW3000 to start up (transition from INIT_RC to IDLE_RC
while (!dwt_checkidlerc()) /* Need to make sure DW IC is in IDLE_RC before proceeding */ { };
if (dwt_initialise(DWT_DW_INIT) == DWT_ERROR)
test_run_info((unsigned char *)"INIT FAILED ");
while (1) { };
/* Configure DW IC. See NOTE 15 below. */
/* if the dwt_configure returns DWT_ERROR either the PLL or RX calibration has failed the host should reset the device */
if (dwt_configure(&config))
test_run_info((unsigned char *)"CONFIG FAILED ");
while (1) { };
/* Configure the TX spectrum parameters (power, PG delay and PG count) */
dwt_configuretxrf(&txconfig_options);
/* Apply default antenna delay value. See NOTE 1 below. */
dwt_setrxantennadelay(RX_ANT_DLY);
dwt_settxantennadelay(TX_ANT_DLY);
/* Next can enable TX/RX states output on GPIOs 5 and 6 to help debug, and also TX/RX LEDs
* Note, in real low power applications the LEDs should not be used. */
dwt_setlnapamode(DWT_LNA_ENABLE | DWT_PA_ENABLE);
// Enabling LEDs here for debug so that for each TX the D1 LED will flash on DW3000 red eval-shield boards.
dwt_setleds(DWT_LEDS_ENABLE | DWT_LEDS_INIT_BLINK);
void loop() {
/* Activate reception immediately. */
/* We assume that the transmission is achieved correctly, poll for reception of a frame or error/timeout. See NOTE 8 below. */
while (!((status_reg = dwt_read32bitreg(SYS_STATUS_ID)) & (SYS_STATUS_RXFCG_BIT_MASK | SYS_STATUS_ALL_RX_TO | SYS_STATUS_ALL_RX_ERR)))
if (status_reg & SYS_STATUS_RXFCG_BIT_MASK)
uint16_t frame_len;
/* Clear good RX frame event in the DW IC status register. */
// dwt_writesysstatuslo(DWT_INT_RXFCG_BIT_MASK);
dwt_write32bitreg(SYS_STATUS_ID, SYS_STATUS_RXFCG_BIT_MASK);
/* A frame has been received, read it into the local buffer. */
frame_len = dwt_read32bitreg(RX_FINFO_ID) & RXFLEN_MASK;
if (frame_len <= RX_BUF_LEN)
dwt_readrxdata(rx_buffer, frame_len, 0);
/* Check that the frame is a poll sent by "DS TWR initiator" example.
* As the sequence number field of the frame is not relevant, it is cleared to simplify the validation of the frame. */
rx_buffer[ALL_MSG_SN_IDX] = 0;
if (memcmp(rx_buffer, rx_poll_msg, ALL_MSG_COMMON_LEN) == 0)
uint32_t resp_tx_time;
int ret;
/* Retrieve poll reception timestamp. */
poll_rx_ts = get_rx_timestamp_u64();
/* Set send time for response. See NOTE 9 below. */
resp_tx_time = (poll_rx_ts + (POLL_RX_TO_RESP_TX_DLY_UUS * UUS_TO_DWT_TIME)) >> 8;
dwt_setdelayedtrxtime(resp_tx_time);
/* Set expected delay and timeout for final message reception. See NOTE 4 and 5 below. */
dwt_setrxaftertxdelay(RESP_TX_TO_FINAL_RX_DLY_UUS);
dwt_setrxtimeout(FINAL_RX_TIMEOUT_UUS);
/* Set preamble timeout for expected frames. See NOTE 6 below. */
dwt_setpreambledetecttimeout(PRE_TIMEOUT);
/* Write and send the response message. See NOTE 10 below.*/
tx_resp_msg[ALL_MSG_SN_IDX] = frame_seq_nb;
dwt_writetxdata(sizeof(tx_resp_msg), tx_resp_msg, 0); /* Zero offset in TX buffer. */
dwt_writetxfctrl(sizeof(tx_resp_msg), 0, 1); /* Zero offset in TX buffer, ranging. */
ret = dwt_starttx(DWT_START_TX_DELAYED | DWT_RESPONSE_EXPECTED);
/* If dwt_starttx() returns an error, abandon this ranging exchange and proceed to the next one. See NOTE 11 below. */
if (ret == DWT_ERROR)
// continue;
/* Increment frame sequence number after transmission of the response message (modulo 256). */
frame_seq_nb++;
dwt_write32bitreg(SYS_STATUS_ID, SYS_STATUS_RXFCG_BIT_MASK| SYS_STATUS_TXFRS_BIT_MASK);
// frame_len = dwt_getframelength();
/* Check that the frame is a final message sent by "DS TWR initiator" example.
* As the sequence number field of the frame is not used in this example, it can be zeroed to ease the validation of the frame. */
if (memcmp(rx_buffer, rx_final_msg, ALL_MSG_COMMON_LEN) == 0)
uint32_t poll_tx_ts, resp_rx_ts, final_tx_ts;
uint32_t poll_rx_ts_32, resp_tx_ts_32, final_rx_ts_32;
double Ra, Rb, Da, Db;
int64_t tof_dtu;
/* Retrieve response transmission and final reception timestamps. */
resp_tx_ts = get_tx_timestamp_u64();
final_rx_ts = get_rx_timestamp_u64();
/* Get timestamps embedded in the final message. */
final_msg_get_ts(&rx_buffer[FINAL_MSG_POLL_TX_TS_IDX], &poll_tx_ts);
final_msg_get_ts(&rx_buffer[FINAL_MSG_RESP_RX_TS_IDX], &resp_rx_ts);
final_msg_get_ts(&rx_buffer[FINAL_MSG_FINAL_TX_TS_IDX], &final_tx_ts);
/* Compute time of flight. 32-bit subtractions give correct answers even if clock has wrapped. See NOTE 12 below. */
poll_rx_ts_32 = (uint32_t)poll_rx_ts;
resp_tx_ts_32 = (uint32_t)resp_tx_ts;
final_rx_ts_32 = (uint32_t)final_rx_ts;
Ra = (double)(resp_rx_ts - poll_tx_ts);
Rb = (double)(final_rx_ts_32 - resp_tx_ts_32);
Da = (double)(final_tx_ts - resp_rx_ts);
Db = (double)(resp_tx_ts_32 - poll_rx_ts_32);
tof_dtu = (int64_t)((Ra * Rb - Da * Db) / (Ra + Rb + Da + Db));
tof = tof_dtu * DWT_TIME_UNITS;
/* Display computed distance on LCD. */
sprintf(dist_str, "DIST: %3.2f m", distance);
test_run_info((unsigned char *)dist_str);
/* as DS-TWR initiator is waiting for RNG_DELAY_MS before next poll transmission
* we can add a delay here before RX is re-enabled again
Sleep(RNG_DELAY_MS - 10); // start couple of ms earlier
else
/* Clear RX error/timeout events in the DW IC status register. */
dwt_write32bitreg(SYS_STATUS_ID,SYS_STATUS_ALL_RX_TO | SYS_STATUS_ALL_RX_ERR);
else
Tag Code
#include “dw3000.h”
// connection pins
float average =0;
String T ;
String Prv_Tag_ID;
String Data;
int readIndex = 0;
float total = 0.0;
byte seqnum;
/* Example application name and version to display on LCD screen. */
#define APP_NAME “DS TWR INIT v1.0”
/* Default antenna delay values for 64 MHz PRF. See NOTE 1 below. /
- The first 10 bytes of those frame are common and are composed of the following fields:
- byte 0/1: frame control (0x8841 to indicate a data frame using 16-bit addressing).
- byte 2: sequence number, incremented for each new frame.
- byte 3/4: PAN ID (0xDECA).
- byte 5/6: destination address, see NOTE 3 below.
- byte 7/8: source address, see NOTE 3 below.
- byte 9: function code (specific values to indicate which message it is in the ranging process).
- The remaining bytes are specific to each message as follows:
- Poll message:
- no more data
- Response message:
- byte 10: activity code (0x02 to tell the initiator to go on with the ranging exchange).
- byte 11/12: activity parameter, not used here for activity code 0x02.
- Final message:
- byte 10 -> 13: poll message transmission timestamp.
- byte 14 -> 17: response message reception timestamp.
- byte 18 -> 21: final message transmission timestamp.
- All messages end with a 2-byte checksum automatically set by DW IC.
/ Frames used in the ranging process. See NOTE 2 below. /
static uint8_t tx_poll_msg[] = { 0x41, 0x88, 0, 0xCA, 0xDE, ‘W’, ‘A’, ‘V’, ‘E’, 0x21 };
static uint8_t rx_resp_msg[] = { 0x41, 0x88, 0, 0xCA, 0xDE, ‘V’, ‘E’, ‘W’, ‘A’, 0x10, 0x02, 0, 0 };
static uint8_t tx_final_msg[] = { 0x41, 0x88, 0, 0xCA, 0xDE, ‘W’, ‘A’, ‘V’, ‘E’, 0x23, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 };
/ Indexes to access some of the fields in the frames defined above. /
/* Buffer to store received response message.
#define RX_BUF_LEN 20
/* Delay between frames, in UWB microseconds. See NOTE 4 below. /
/ Delay between frames, in UWB microseconds. See NOTE 1 below. /
#ifdef RPI_BUILD
#define POLL_TX_TO_RESP_RX_DLY_UUS 240
#endif //RPI_BUILD
#ifdef STM32F429xx
/ Receive response timeout. See NOTE 5 below. */
#ifdef RPI_BUILD
#define RESP_RX_TIMEOUT_UUS 270
#endif //RPI_BUILD
#ifdef STM32F429xx
#define RESP_RX_TIMEOUT_UUS 210
#define RESP_RX_TIMEOUT_UUS 400
#define RESP_RX_TO_FINAL_TX_DLY_UUS 240
/* Preamble timeout, in multiple of PAC size. See NOTE 7 below. */
/* Time-stamps of frames transmission/reception, expressed in device time units. */
static uint64_t poll_tx_ts;
static uint64_t resp_rx_ts;
static uint64_t final_tx_ts;
/* Values for the PG_DELAY and TX_POWER registers reflect the bandwidth and power of the spectrum at the current
- temperature. These values can be calibrated prior to taking reference measurements. See NOTE 8 below. */
uint16_t add = 0;
void setup() {
// DEBUG monitoring
test_run_info((unsigned char *)APP_NAME);
/* Configure SPI rate, DW3000 supports up to 38 MHz /
/ Reset DW IC */
spiSelect(PIN_SS);
while (1) { };
/* Configure DW IC. See NOTE 2 below. */
while (1) { };
/* Set expected response's delay and timeout. See NOTE 4, 5 and 7 below.
* As this example only handles one incoming frame with always the same delay and timeout, those values can be set here once for all. */
dwt_setrxaftertxdelay(POLL_TX_TO_RESP_RX_DLY_UUS);
dwt_setrxtimeout(RESP_RX_TIMEOUT_UUS);
void loop() {
/* Write frame data to DW IC and prepare transmission. See NOTE 9 below. /
tx_poll_msg[ALL_MSG_SN_IDX] = frame_seq_nb;
dwt_writetxdata(sizeof(tx_poll_msg), tx_poll_msg, 0); / Zero offset in TX buffer. /
dwt_writetxfctrl(sizeof(tx_poll_msg) + FCS_LEN, 0, 1); / Zero offset in TX buffer, ranging. */
/* Start transmission, indicating that a response is expected so that reception is enabled automatically after the frame is sent and the delay
* set by dwt_setrxaftertxdelay() has elapsed. */
dwt_starttx(DWT_START_TX_IMMEDIATE | DWT_RESPONSE_EXPECTED);
/* Increment frame sequence number after transmission of the poll message (modulo 256). */
frame_seq_nb++;
uint16_t frame_len;
/* Clear good RX frame event and TX frame sent in the DW IC status register. */
dwt_write32bitreg(SYS_STATUS_ID,SYS_STATUS_RXFCG_BIT_MASK | SYS_STATUS_TXFRS_BIT_MASK);
/* Check that the frame is the expected response from the companion "DS TWR responder" example.
if (memcmp(rx_buffer, rx_resp_msg, ALL_MSG_COMMON_LEN) == 0)
uint32_t final_tx_time;
int ret;
/* Retrieve poll transmission and response reception timestamp. */
poll_tx_ts = get_tx_timestamp_u64();
resp_rx_ts = get_rx_timestamp_u64();
/* Compute final message transmission time. See NOTE 11 below. */
final_tx_time = (resp_rx_ts + (RESP_RX_TO_FINAL_TX_DLY_UUS * UUS_TO_DWT_TIME)) >> 8;
dwt_setdelayedtrxtime(final_tx_time);
/* Final TX timestamp is the transmission time we programmed plus the TX antenna delay. */
final_tx_ts = (((uint64_t)(final_tx_time & 0xFFFFFFFEUL)) << 8) + TX_ANT_DLY;
/* Write all timestamps in the final message. See NOTE 12 below. */
final_msg_set_ts(&tx_final_msg[FINAL_MSG_POLL_TX_TS_IDX], poll_tx_ts);
final_msg_set_ts(&tx_final_msg[FINAL_MSG_RESP_RX_TS_IDX], resp_rx_ts);
final_msg_set_ts(&tx_final_msg[FINAL_MSG_FINAL_TX_TS_IDX], final_tx_ts);
/* Write and send final message. See NOTE 9 below. */
tx_final_msg[ALL_MSG_SN_IDX] = frame_seq_nb;
dwt_writetxdata(sizeof(tx_final_msg), tx_final_msg, 0); /* Zero offset in TX buffer. */
dwt_writetxfctrl(sizeof(tx_final_msg) + FCS_LEN, 0, 1); /* Zero offset in TX buffer, ranging bit set. */
ret = dwt_starttx(DWT_START_TX_DELAYED);
/* If dwt_starttx() returns an error, abandon this ranging exchange and proceed to the next one. See NOTE 13 below. */
if (ret == DWT_SUCCESS)
/* Poll DW IC until TX frame sent event set. See NOTE 6 below. */
while (!(dwt_read32bitreg(SYS_STATUS_ID) & SYS_STATUS_TXFRS_BIT_MASK))
/* Clear TXFRS event. */
dwt_write32bitreg(SYS_STATUS_ID, SYS_STATUS_TXFRS_BIT_MASK);
/* Increment frame sequence number after transmission of the final message (modulo 256). */
frame_seq_nb++;
else
dwt_write32bitreg(SYS_STATUS_ID,SYS_STATUS_ALL_RX_TO | SYS_STATUS_ALL_RX_ERR | SYS_STATUS_TXFRS_BIT_MASK);
/* Execute a delay between ranging exchanges. */
Sleep(RNG_DELAY_MS);
