Error Makefile doing "make install"
Hi. I have the MDEK1001 Kit and im trying to use the VirtualBox of DWM1001. Now im installing the openOCD-0.10.0. When i do the “./cofigure” everything is fine:
OpenOCD configuration summary
MPSSE mode of FTDI based devices yes (auto)
ST-Link JTAG Programmer yes (auto)
TI ICDI JTAG Programmer yes (auto)
Keil ULINK JTAG Programmer yes (auto)
Altera USB-Blaster II Compatible yes (auto)
Versaloon-Link JTAG Programmer yes (auto)
OSBDM (JTAG only) Programmer yes (auto)
eStick/opendous JTAG Programmer yes (auto)
Andes JTAG Programmer yes (auto)
USBProg JTAG Programmer no
Raisonance RLink JTAG Programmer no
Olimex ARM-JTAG-EW Programmer no
CMSIS-DAP Compliant Debugger yes (auto)
Altera USB-Blaster Compatible no
ASIX Presto Adapter no
OpenJTAG Adapter no
SEGGER J-Link Programmer yes (auto)
When i do “make” everything is fine i think, but when i do the “make install” i got this:
dw@dw:~/Downloads/openocd-0.10.0$ make install
Makefile:4252: warning: overriding recipe for target 'check-recursive'
Makefile:3665: warning: ignoring old recipe for target 'check-recursive'
make  install-recursive
make[1]: Entering directory '/home/dw/Downloads/openocd-0.10.0'
Making install in jimtcl
make[2]: Entering directory '/home/dw/Downloads/openocd-0.10.0/jimtcl'
make[2]: Nothing to be done for 'install'.
make[2]: Leaving directory '/home/dw/Downloads/openocd-0.10.0/jimtcl'
Making install in src/jtag/drivers/libjaylink
make[2]: Entering directory '/home/dw/Downloads/openocd-0.10.0/src/jtag/drivers/libjaylink'
Making install in libjaylink
make[3]: Entering directory '/home/dw/Downloads/openocd-0.10.0/src/jtag/drivers/libjaylink/libjaylink'
make[4]: Entering directory '/home/dw/Downloads/openocd-0.10.0/src/jtag/drivers/libjaylink/libjaylink'
make[4]: Leaving directory '/home/dw/Downloads/openocd-0.10.0/src/jtag/drivers/libjaylink/libjaylink'
make[3]: Leaving directory '/home/dw/Downloads/openocd-0.10.0/src/jtag/drivers/libjaylink/libjaylink'
make[3]: Entering directory '/home/dw/Downloads/openocd-0.10.0/src/jtag/drivers/libjaylink'
make[4]: Entering directory '/home/dw/Downloads/openocd-0.10.0/src/jtag/drivers/libjaylink'
make[4]: Nothing to be done for 'install-exec-am'.
make[4]: Leaving directory '/home/dw/Downloads/openocd-0.10.0/src/jtag/drivers/libjaylink'
make[3]: Leaving directory '/home/dw/Downloads/openocd-0.10.0/src/jtag/drivers/libjaylink'
make[2]: Leaving directory '/home/dw/Downloads/openocd-0.10.0/src/jtag/drivers/libjaylink'
make[2]: Entering directory '/home/dw/Downloads/openocd-0.10.0'
make[3]: Entering directory '/home/dw/Downloads/openocd-0.10.0'
 /bin/mkdir -p '/usr/local/bin'
  /bin/bash ./libtool   --mode=install /usr/bin/install -c src/openocd '/usr/local/bin'
libtool: install: /usr/bin/install -c src/openocd /usr/local/bin/openocd
/usr/bin/install: cannot create regular file '/usr/local/bin/openocd': Permission denied
Makefile:2411: recipe for target 'install-binPROGRAMS' failed
make[3]: *** [install-binPROGRAMS] Error 1
make[3]: Leaving directory '/home/dw/Downloads/openocd-0.10.0'
Makefile:3970: recipe for target 'install-am' failed
make[2]: *** [install-am] Error 2
make[2]: Leaving directory '/home/dw/Downloads/openocd-0.10.0'
Makefile:3665: recipe for target 'install-recursive' failed
make[1]: *** [install-recursive] Error 1
make[1]: Leaving directory '/home/dw/Downloads/openocd-0.10.0'
Makefile:3964: recipe for target 'install' failed
make: *** [install] Error 2
I dont know what im doing bad.
Thank you for your time
Your problem is
You should install “system programs”, i.e. everything outside your /home/username as the root.
“su”
or
“sudo su”
yeah , but i coudnt find the password for sudo
you have an internet, google it!
If you are using the virtual image you have downloaded from DW website, use sudo su, the password is the same (user dw should be in the sudoers group).
thanks for your help ! Solved !
