Easy way to measure voltage difference between 2 nodes in .op
When I place the mouse cursor on top of a node the DC voltage appears, however, is there an easy way to show the differential voltage between 2 nodes? For example, in LTSPICE when you click on a node, then keep the mouse button pressed and move the pointer to another node and release the button, it will display the differential voltage between those two nodes. Is there a way to do that in QSPICE?
Hold ALT then first click on node1 then on node2. Best regards
Hello Ivan. I tried that but the difference does not appear on the schematic, but rather on the waveform viewer. It is a bit impractical.
