Does the DWS3000 module use the same land pattern as the DWS1000? I’ve been unable to locate any dimension data on the DWS3000 module. Also, if a footprint is available in KiCad, please advise
The module used on the DWS3000 is the DWM3000. See here for Altium Symbol and Pattern for the DWM3000.
Thank you for the reply. Unfortunately not all of your customers use Altium and can not open the file. Can you supply a pdf drawing that details the physical dimensions of the part and / or suggested land pattern?
FYI - The DWM1000 and DWM3000 Land pattern are identical
