DWM3001CDK Source Code for UCI
I’m currently using the DWM3001CDK for a project and would like to measure distance using an Android smartphone. I have successfully tested the repository at GitHub - sasodoma/uwb-ranging: UWB Ranging with DWM3001CDK and Android, which worked as expected.
However, in order to use the UCI in this example, I need to load the provided .hex file included in the SDK. Could you please let me know if the corresponding source code is available?
Additionally, I’d like to know whether it’s possible to port the implementation from FreeRTOS to Zephyr.
Best regards.
Hi @Portilha !
You can go to DWM3001CDK - Qorvo, go to the tab “Evaluation Tools” and look for the DW3xxx & QM3xxx SDK.
It has the binaries and sources for the supported platforms, which include DW3001CDK, and the documentation to build and run them.
Kind regards!
