We are using DWM3000EVB with the recommended ST NUCLEO-F429ZI Evaluation board.
We are using the TWR_Demo application.“Firmware Version” : “6.0.230105”.
We are facing an issue with the two anchors and one tag. (We are not getting correct measurements in which anchor is more distance away from the tag and which is near to the tag is getting correct measurements).
We are getting correct measurements from my anchors, if I only use one tag and one anchor(observing this in the DecaPDOARTLS application).
We have given different addresses to the anchors.
Do we need to do any other changes to get it to work properly?
Please advice.
Thank you in advance for your help.
