Can I do two-way ranging RTLS with the DWM3000evb and STM32F429ZI boards. Yes, we have an open source API-Examples. But When I try to run these API Examples, I always encounter with some kind of problems.
If anyone runs the API-Examples, can you explain “how to run it” for me ?
Examples for API-Examples;
reading_device_id
simple_tx
simple_rx etc.
Once you did that, you’ll find a file named “example_selection.h” under DW3XXX_API_rev9p3/API/Src where you’ll need to uncommend the test you want to do, then build the application and flash it to the chip.
To do two-way ranging, I would recommend to start with ex_05a and ex_05b for double sided two way ranging.
