HI, im looking to work with a DWM3000 module. i need 3 and i already have a microcontroller to controll the system. so because the module is very small i dont think that i’ll be able to solder the very small pads or if its even possible to do it.. so becouse i dont want to buy 3 of the much more expensive esp32 integrated version. i wanted to ask if anyone else might have a solusion, i admit that i am not very fremiliar with this tech. thanks!
If you are needing this for prototyping, you could use the DWM3000EVB (DWM3000EVB - Qorvo) for your prototype. This will expose all of the connections from the module to header pins and is only $30.
Otherwise, you can directly solder to the DWM3000 module with some care.
