I am attempting to use the DWM3000 module shield and the Nucleo-F446RE boards to run example code found at the link at the bottom of this email. Specifically, I am trying to run ex_01a_simple_tx and ex_02a_simple_rx. Using the IDE for the nucleo board, the example code will not run. In the build file is the line:
arm-none-eabi-size “DW3000_API_CubeMX.bin”
Please let me know how I can get this code to run on the boards.
Thank you,
Matthew Hart
