At point 8.2.23 of the DWM3000 user manual, we can read about the indirect pointers : “… The indirect register address is needed when accessing the register contents starting at offset > 127.”
Is it correct since the 4 types of SPI command need an offset limited at 6 bits which allows access at 64 bytes of register. Is it correct or not?
Thank you.
GOFFIN David
Regulation-Mesure
Section 2.3.1.2 of the user manual describes how the addresses are sent over SPI.
Registers have a 5 bit address and then a optional offset within that register.
That offset value is 7 bits (6 bits in the second bytes of the transaction and 1 bit in the LSB of the first byte).
This means you can access 32 registers with an offset of up to 127 directly.
