I understand that each DWM1001C has node ID embedded inside preprogrammed. Its 8 byte long, and occasionally referenced by the last 2 byte.
My questions about it is:
- Where does the node ID stored?
- Is the node ID modifiable?
Hi @arama
you can only change the BLE node label by “nls” command or with dwm_label_write API command.
Cheers
JK
