I have been attempting to follow the DWM1001 Firmware User Guide to evaluate tags/beacons. I re-flashed the dev board as described in section 3.3, and have run into a few problems.
Switching to shell mode is now very flaky. Pressing return several times generally results in an ‘@’ being returned, rather than switching to shell mode. After several dozen or several hundred presses it will go into shell mode, but this can take a long time and is generally rather frustrating.
I can’t join/set the network. using ‘si’ I get the the pan ID has been reset to 0000. The nis command reports success, but doesn’t actually change anything.
dwm> nis FD5C
nis: ok
dwm> si
[000541.880 INF] sys: fw2 fw_ver=x01030001 cfg_ver=x00010700
[000541.880 INF] uwb0: panid=x0000 addr=xDECA9AABC0A2591A
[000541.890 INF] mode: tn (act,twr,np,le)
[000541.890 INF] uwbmac: disconnected
[000541.890 INF] uwbmac: bh disconnected
[000541.900 INF] cfg: sync=0 fwup=0 ble=1 leds=1 le=1 lp=0 stat_det=1 (sens=1) mode=0 upd_rate_norm=1 upd_rate_stat=100 label=DW591A
[000541.910 INF] enc: off
[000541.910 INF] ble: addr=C2:BB:9E:BE:5D:15
dwm>
How do I fix these issues?
Thanks!
