Is it possible to configure a node as a listener in the user application thread?
I need a node to start logging the locations of all tags via UART, without configuring it in the Shell mode.
Thanks,
David.
Thanks,
David.
Hi
it seems that it is possible check DWM1001-API-Guide command dwm_cfg_anchor_set - set uwb_mode to 1
Regards
drg
Does that work for you?
Did this end up working for anyone? I need to accomplish the same task
