Hi
This probably was asked like a thousand times, please forgive me.
Does Decawave provide TDoA Anchor software for the DWM1000 module?
With regards,
SzK
Hi
With regards,
SzK
No. The dwm1000 module has no MCU. Also the dwm1000 has a crystal, which is not very good for TDoA anchor.
Thanks for the quick response!
If the DWM1000 wouldnt be a good choice for TDoA Anchor, than the DWM10004C can be (with the right MCU)?
No. DWM1004 is supposed to be a TDoA tag type application.
For anchors you need either custom design or you can purchase the Licensed SW+HW, this is called TTK1000. This is not such easy as you might think and everything is already done by few companies, including Decawave.
I know its made to be a TDoA Tag. Im just courious, what are the possibilities.
With an mcu and custom pcb, (and software of course), the DWM1004 could work as an anchor?
(If I good to know, even the DWM1000 can work as a TDoA Anchor with mcu and custom pcb)
Sorry, cannot recall… why don’t you write your own and would not give it to the rest “for free”?
