Does the DWM1000 have Panama Regulatory Certification. If so, how do I obtain a copy.
Does Panama fall to the following certifications?
The DWM1000 doesn’t have any regulatory certifications for anywhere. If can be made to pass most certifications but it’s up to you to do the testing and get that certification.
The DWM1001 does have certification to a number of standards if running PANS firmware. If running custom UWB firmware then it is again up to you to get the certifications.
As soon as you run your own UWB firmware the power and transmit duty cycle will change. It is impossible to produce a generic certification for the modules in that situation.
