What is the maxium current drawn from by the DWM1000?
I am using it with a NODEMCU to find the position but occasionally it just stops sending and receiving messages randomly.
Hi
See DWM1000 datasheet.
DWM1000-Datasheet.pdf (1.6 MB)
But did you find out why it stops randomly? Do you see errors? Did you check the status of the device? Why do think its a current issue?
To debug, please see APS022 our debug application note.
APS022_Debugging_DW1000_based_products_systems.pdf (999.6 KB)
Regard,
leo
Hey Leylan,
Were you able to solve the issue? Could you share the results of using NODEMCU with MCU1000 and which library you used for the same.
