DW3220 EOL Replacement Compatability
We are currently using the DW3220 in production and have been notified that it is going EOL shortly. To prepare for this, I am searching for a drop-in pin-compatible chip that maintains the dual antenna functionality.
I have found the DW3300Q which appears to satisfy our needs, but I have 2 questions that remain.
  1. The DW3000Q appears to share the same footprint as the DW3320, even though one is marked QFN while the other is a LGA. Are these two units, purely from a footprint perspective, truly footprint compatible?
  2. There is a pin configuration difference on pin 3 between that I was hoping to get clarification on.
  • On the DW3000 QFN, pin 3 (GPIO0/RXOKLED) can be used as a GPIO.
  • On the DW3300Q LGA, pin 3 (SPI2CLK) is only marked as DI.
    Is the DW3300Q pin 3 capable of being used as a GPIO, or is it truly input only?
Thank you,
Zach
Hi Zach,
These 2 chips are not footprint compatible and unfortunately, there is not a drop in compatible chip replacement for the DW3220 which has 2 antenna ports. In addition to the DW3300Q, if you can tolerate a WLCSP, the QM33120W would be a good choice.
This pin cannot be used as a GPIO.
Thank you for the quick reply.
Unfortunately any footprint change to the device is an update to all of our approvals and is likely not an option at this point.
Cheers,
Zach
One more question while I am on the topic.
Are there plans to phase out the DW3210? Or was the decision to remove the DW3220 made in order to keep the DW3210 in production for the considerable future?
Thank you
Zach
There are no current plans to EoL the DW3210 or DW3110.
Currently, DW3120 and DW3220 (both of the 2 antenna parts of the DW3000 family) are in LTB status. These parts were planned for obsolescence due to lack of demand (as mentioned in the Product Change Notice).
In summary, the parts that will continue for the foreseeable future for our transceivers are:
  • DW3110 - WLCSP, 1 antenna port
  • DW3210 - QFN, 1 antenna port
  • DW3300Q - LGA, 2 antenna ports, support for Japan pulse shape, automotive qualified
  • QM33110W - WLCSP, 1 antenna port, support for Japan pulse shape
  • QM33120W - WLCSP, 2 antenna ports, support for Japan pulse shape
All of these parts are in production.
Swapping the radio chip will invalidate all your approvals anyway.
Worth separating module certifications from end-product approvals: if the DW3220 sits inside an already-certified module, the module vendor’s certification is what changes; the end product may still need a permissive change or re-test depending on the regulator. If the chip itself is the certified radio, then yes, a swap generally triggers recertification. Either way, last-time-buy stock may be the only route if no footprint change is allowed.
