DW3000 Customer OTP space
I want to use the customer OTP address space 0x10 to 0x1D to store some application related values. When i check the space on a dwm3001c, not all address fields are zero. Can someone explain what these values are? They are also different on different boards.
address: 0x10 Value: 0x0000
address: 0x11 Value: 0x91919191
address: 0x12 Value: 0x0000
address: 0x13 Value: 0x91919191
address: 0x14 Value: 0x0000
address: 0x15 Value: 0x0000
address: 0x16 Value: 0x0000
address: 0x17 Value: 0x0000
address: 0x18 Value: 0x0000
address: 0x19 Value: 0x748b
address: 0x1a Value: 0xffd7ffa3
address: 0x1b Value: 0xf000f0
address: 0x1c Value: 0x40164016
address: 0x1d Value: 0x0000
How ever, on a custom board using the DW3000 IC, all the addresses are zero.
Each DWM3001C device is factory calibrated, with calibration data stored in OTP.
Please check the DWM3001C data sheet for details of the OTP memory map.
https://www.qorvo.com/products/d/da008289
Thanks for the response. This explains why.
I was only looking at DW3000 user manual.
