DW3_QM33_SDK_1.0.2 compile error
[ 99%] Building C object CMakeFiles/DWM3001CDK-DW3_QM33_SDK_CLI-FreeRTOS.elf.dir/01530722206004f38c680e13ba1fa14f/main_cli.c.obj
make[2]: *** No rule to make target ‘C:/Users/wpb/VS_code/DW3_QM33_SDK_1.0.2/SDK/Firmware/DW3_QM33_SDK_1.0.2/Libs/uwbstack_libs/delivery/fira/Release/lib/arm-cortex-m4-hard_floating/uwbmac_msg_serialization/libuwbmac_msg_serialization_fira_arm-cortex-m4-hard_floating_rtos_R12.7.0-00288-gb8203d558863.a’, needed by ‘DWM3001CDK-DW3_QM33_SDK_CLI-FreeRTOS.elf’. Stop.
make[2]: *** Waiting for unfinished jobs…
[ 99%] Building C object CMakeFiles/DWM3001CDK-DW3_QM33_SDK_CLI-FreeRTOS.elf.dir/561af9185ef97ac3cddc6077e92fe0f7/DW3_QM33_SDK-FreeRTOS-Common/hooks.c.obj
CMakeFiles\Makefile2:554: recipe for target ‘CMakeFiles/DWM3001CDK-DW3_QM33_SDK_CLI-FreeRTOS.elf.dir/all’ failed
make[1]: *** [CMakeFiles/DWM3001CDK-DW3_QM33_SDK_CLI-FreeRTOS.elf.dir/all] Error 2
Makefile:89: recipe for target ‘all’ failed
make: *** [all] Error 2
  • The terminal process “C:\WINDOWS\System32\WindowsPowerShell\v1.0\powershell.exe -Command make all V=1 -j” terminated with exit code: 1.
  • Terminal will be reused by tasks, press any key to close it.
