I’m working with two EVK boards and am attempting to measure the TX and RX delay of the DW1000 chip, I’ve been unable to find any mention of it in the user manual or data sheet. I am using a modified version of the Decawave 3.05 software, a logic analyzer, and the LCD_RW GPIO pin to make the measurements, lowering it on the TX board when the transmission is being sent over SPI and raising it when the callback for successful transmission occurs. I am using a similar approach for the receiver. Using this method I get a TX delay of approximately 200 us, and a RX delay of approximately 12 us. Essentially I’m wondering if these are expected values or if I’ve made an incorrect assumption/improper implementation somewhere as the TX delay is significantly larger.
The code I’m using for the transmit side is as follows:
[code]/*! ----------------------------------------------------------------------------
- @file main.c
- @brief main loop for the DecaRanging application
- @attention
- Copyright 2016 © DecaWave Ltd, Dublin, Ireland.
- All rights reserved.
@author DecaWave
#include “port.h”
#include “compiler.h”
#include “instance.h”
#include “deca_types.h”
#include “deca_spi.h”
#include “deca_device_api.h”
extern int dw_main(void);
extern uint32 inittestapplication(uint8 s1switch);
extern int decarangingmode(uint8 s1switch);
instanceConfig_t chConfig2[8] ={
//mode 1 - S1: 7 off, 6 off, 5 off
2, // channel
3, // preambleCode
DWT_PRF_16M, // prf
DWT_BR_110K, // datarate
DWT_PLEN_1024, // preambleLength
DWT_PAC32, // pacSize
1, // non-standard SFD
(1025 + 64 - 32) //SFD timeout
//mode 2
2, // channel
3, // preambleCode
DWT_PRF_16M, // prf
DWT_BR_6M8, // datarate
DWT_PLEN_128, // preambleLength
DWT_PAC8, // pacSize
0, // non-standard SFD
(129 + 8 - 8) //SFD timeout
//mode 3
2, // channel
9, // preambleCode
DWT_PRF_64M, // prf
//mode 4
2, // channel
9, // preambleCode
DWT_PRF_64M, // prf
//mode 5
5, // channel
3, // preambleCode
DWT_PRF_16M, // prf
//mode 6
5, // channel
3, // preambleCode
DWT_PRF_16M, // prf
//mode 7
5, // channel
9, // preambleCode
DWT_PRF_64M, // prf
//mode 8
5, // channel
9, // preambleCode
DWT_PRF_64M, // prf
void instance_txcallback2(const dwt_cb_data_t *txd)
GPIO_SetBits(SPIy_GPIO, LCD_RW);
void instance_rxtimeoutcallback2(const dwt_cb_data_t *rxd)
void instance_rxgoodcallback2(const dwt_cb_data_t *rxd)
void instance_rxerrorcallback2(const dwt_cb_data_t *rxd)
int main(void)
peripherals_init();
spi_peripheral_init();
Sleep(2000);
port_DisableEXT_IRQ();
uint8 s1switch = port_is_boot1_on(0) << 1 // is_switch_on(TA_SW1_2) << 2
| port_is_switch_on(TA_SW1_3) << 2
| port_is_switch_on(TA_SW1_4) << 3
| port_is_switch_on(TA_SW1_5) << 4
| port_is_switch_on(TA_SW1_6) << 5
| port_is_switch_on(TA_SW1_7) << 6
| port_is_switch_on(TA_SW1_8) << 7;
Sleep(1000);
if(inittestapplication(s1switch) == (uint32)-1)
int x = 0;
return 0; //error
Sleep(5000);
port_EnableEXT_IRQ();
int dr_mode = decarangingmode(s1switch);
instance_config(&chConfig2[dr_mode]);
dwt_setinterrupt(DWT_INT_TFRS | DWT_INT_RFCG | (DWT_INT_ARFE | DWT_INT_RFSL | DWT_INT_SFDT | DWT_INT_RPHE | DWT_INT_RFCE | DWT_INT_RFTO /*| DWT_INT_RXPTO*/), 1);
dwt_setcallbacks(instance_txcallback2, instance_rxgoodcallback2, instance_rxtimeoutcallback2, instance_rxerrorcallback2);
int length = 3;
uint8 * data = (uint8 *)malloc(length-2);
data[0] = 'H';
bool stateabcd = false;
while(1){
stateabcd = !stateabcd;
if(stateabcd){
//drive the RSTn pin low
dwt_writetxdata(length, data, 0) ; // write the frame data
dwt_writetxfctrl(length, 0, 0);
GPIO_ResetBits(SPIy_GPIO, LCD_RW);
dwt_starttx(DWT_START_TX_IMMEDIATE);
GPIO_ResetBits(GPIOC, GPIO_Pin_6);
GPIO_ResetBits(GPIOC, GPIO_Pin_7);
GPIO_SetBits(GPIOC, GPIO_Pin_8);
GPIO_SetBits(GPIOC, GPIO_Pin_9);
else
GPIO_ResetBits(GPIOC, GPIO_Pin_8);
GPIO_ResetBits(GPIOC, GPIO_Pin_9);
GPIO_SetBits(GPIOC, GPIO_Pin_6);
GPIO_SetBits(GPIOC, GPIO_Pin_7);
Sleep(1000);
return 0;
}[/code]
The receive code can be seen below:
- @file main.c
- @attention
@author DecaWave
#include “port.h”
//#include “deca_spi.h”
2, // channel
3, // preambleCode
DWT_PRF_16M, // prf
//mode 2
2, // channel
3, // preambleCode
DWT_PRF_16M, // prf
//mode 3
2, // channel
9, // preambleCode
DWT_PRF_64M, // prf
//mode 4
2, // channel
9, // preambleCode
DWT_PRF_64M, // prf
//mode 5
5, // channel
3, // preambleCode
DWT_PRF_16M, // prf
//mode 6
5, // channel
3, // preambleCode
DWT_PRF_16M, // prf
//mode 7
5, // channel
9, // preambleCode
DWT_PRF_64M, // prf
//mode 8
5, // channel
9, // preambleCode
DWT_PRF_64M, // prf
int x =0;
x++;
int x =0;
x++;
bool hasUnprocessedRxd = false;
dwt_cb_data_t unprocessedRxd;
memcpy(&unprocessedRxd, rxd, sizeof(dwt_cb_data_t));
hasUnprocessedRxd = true;
int x =0;
x++;
int main(void)
//int ret = dw_main();
peripherals_init();
Sleep(1000);
inittestapplication(s1switch);
instance_config(&chConfig2[dr_mode]) ;
while(1){
if(stateabcd){
if (hasUnprocessedRxd) {
uint16 length = unprocessedRxd.datalength;
uint8 data[length];
dwt_readrxdata(data, length, 0);
if(data[0]=='H'){
bool test1 = true;
else
return 0;
}[/code]
