DW1000 does not receive data when using a temperature-compensated crystal oscillator. What is the reason?
Can you please give a bit more detail that it doesn’t work, we know nothing about your system or setup so without more information it’s hard to be of much help.
You have a PCB with a TCXO and it’s not getting data?
Does it work with a standard crystal on the same PCB?
Can you talk on the SPI bus and read the device ID ok when using the TCXO?
Have you checked the clock signal with a scope?
