Default tx power setting?
I have built custom dw1000 board and i would like to verify the RF performance of PCB layout. I try to find a default reference output power as a baseline so i can compare it with what i actually measured.
In datasheet the TX AC characteristics is marked as -39dBm/MHz, i am not sure under which internal gain setting the value is given?
I can found in datasheet the figures of TX channel output (as attached), however it did not say under which condition these figures are measured. Are they measured using default [size=small][font=Arial]TX Power Control register [/font][/size]values(as attached)? Can you provide detailed list of condition of measurements?
Thanks.
/Roland
