I am attempting to setup the Decawave using the app on an android tablet; as I have done countless times before. However I get several errors during this process each error is virtually the same: ERROR GATT_REPRESENTATION. Problem while decoding Node statistics characteristics expecting multiplication of 8 bytes, remaining 60 instead. Does anybody know what this mean?
it looks like you use different version of the DRTLS Android application and the firmware.
Please check that both come from PANS Release 2.
Cheers,
TDK
Okay I sort of suspected as much since right after I just used the PANS_2 to flash the DWM1001-dev boards is when I started getting the error. Because I already flashed with the PANS Release 2 can you please provide a link to the DRTLS android Application that is compatible with the PANS_2 firmware?
everything can be found on the Decawave website.
Download “DWM1001, DW10001-DEV and MDEK1001 Documents, Source Code, Android Application & Firmware Image” from https://www.decawave.com/product-documentation/
Cheers,
TDK
