Hey, I’ve been playing with dwm1001 and I managed to send a message via broadcast.
But my goal is to send message from one dwm1001 (master), the other dwm1001 will send msg including distance between master and itself and its address.
Thanks!
#include "contiki.h"
#include "net/rime/rime.h"
#include <stdio.h>
#define BROADCAST
#define RIME_CHANNEL 146
#define RIME_TYPE "broadcast"
static struct broadcast_conn bc;
static const struct broadcast_callbacks bc_cb = {};
PROCESS(frame_sender_process, "SENDER");
AUTOSTART_PROCESSES(&frame_sender_process);
PROCESS_THREAD(frame_sender_process, ev, data)
static struct etimer timer;
static unsigned long tx_count = 0;
PROCESS_EXITHANDLER(broadcast_close(&bc);)
PROCESS_BEGIN();
printf("%s sender %d.%d starting...\r\n",
RIME_TYPE,
linkaddr_node_addr.u8[0],
linkaddr_node_addr.u8[1]);
broadcast_open(&bc, RIME_CHANNEL, &bc_cb);
etimer_set(&timer, CLOCK_SECOND);
while (1)
PROCESS_WAIT_EVENT();
if (ev == PROCESS_EVENT_TIMER)
tx_count++;
printf("Sending %s message: %d seq\r\n",
RIME_TYPE, tx_count);
char *msg = "Hello";
packetbuf_clear();
packetbuf_set_datalen(sprintf(packetbuf_dataptr(),
"%s", msg) +
1);
broadcast_send(&bc);
etimer_reset(&timer);
PROCESS_END();
// recv
#include "net/packetbuf.h"
#include <stdio.h>
PROCESS(frame_receiver_process, "RECEIVER");
AUTOSTART_PROCESSES(&frame_receiver_process);
static unsigned long rx_count = 0;
#define BROADCAST
static void recv_callback(struct broadcast_conn *c, const linkaddr_t *from);
static const struct broadcast_callbacks bc_cb = {recv_callback};
// printf("msg got\n");
// int tx_count = -1;
// if (packetbuf_datalen() == sizeof(tx_count))
// packetbuf_copyto(&tx_count);
printf("| %s | message received from %02x.%02x (%i) - RSSI = %d\r\n",
(char *)packetbuf_dataptr(),
from->u8[0], from->u8[1], rx_count,
(signed short)packetbuf_attr(PACKETBUF_ATTR_RSSI));
// packetbuf_dataptr();
// packetbuf_clear();
rx_count++;
PROCESS_THREAD(frame_receiver_process, ev, data)
PROCESS_BEGIN();
printf("BQU:0:%u:%u\r\n", RTIMER_NOW(), RTIMER_ARCH_SECOND);
printf("R %d.%d starting...\r\n", linkaddr_node_addr.u8[0],
etimer_set(&timer, CLOCK_SECOND * 5);
while (1)
// printf("Receiver %lu\r\n", rx_count);
// print_sys_status(dw_read_reg_64( DW_REG_SYS_STATUS, DW_LEN_SYS_STATUS ));
PROCESS_END();
