I’m trying to connect the DWM1001-DEV to my Windows 10 computer using Bluetooth. When I go to settings/Bluetooth in Windows and attempt to add the device, the device is found and the blue LED on the board stays blue for 2-5 seconds and then connection fails and says “Try connecting your device again”.
Has anyone been able to connect to these via Windows 10/Bluetooth?
I’ve been successfully working with them via USB to Serial & Putty but I’m looking to transition to a remote connection and write some code but I won’t get very far if I can’t connect to the board.
So far I’ve been using the PANS firmware (latest version) that I updated the boards to when I got them.
