- Is it possible to change the DWM1001-DEV from UWB channel 5 to a different channel?
- Is it possible to change the DWM1001-DEV data rate from 6.8Mbps to a lower amount?
I’ve poured over the support documentation and firmware source code but can’t find anything definitive. I understand that changing the channel is not good for the built-in antenna… but I was hoping to just try changing the channel and data rate in order to test out maximizing the range and object penetration of the DWM1001-DEV from the MDEK1001 kit.
If these changes aren’t possible please let me know… otherwise if they are, being pointed in the right direction in regards to what to look at in the programming of the devices would be much appreciated.
Thank you.
